1 - 17 of 17 Posts
You could try Tasca Ford or White Bear Lake Autonation, but I do believe you are searching for a "unicorn" part. Plenty of used ones on Ebay, maybe one in "like new" condition.
the post I lost trying to edit ..
lightning version of my air box .. tube from box to t-b changes
the night I put mine in I went for a good long drive
"real time" mpg shown on my edge tuner went from 21 to 23 mpg - driving at a steady 40-50 mph
the volant filter is not oiled so no worries about the MAF
- and NO TUNE needed because .. maf - disconnect battery , ecu "relearns' at startup
and mine's going on eight or nine years old .. maybe?
I haven't needed to do anything but wash the filter a few times - prob 40-50 thousand miles on it now (?)
deff a better filter element than K&N
the coil connectors I have to recommend outright every time as the single best thing I've done to my modest old truck
probably the best spent $200 in the truck
solid stainless cable .. coil to plug (blue silicone boots)
gave me a throttle pedal with "snap on" - snap off" crispness and took away a fuzziness I didn't know the truck had ..until..
I doubt the MSD coils make much difference - though I haven't had to replace one yet (going on 4 years)
truck's had 14-16 ford coils since new so I refuse to give ford more $$ now..
after the install I thought about those ford spring connectors .. and high voltage cable that sometimes move when the current first goes through them....thus going back to my comment about "fuzziness"
N A 5.4 with air filter , coils & connectors and an edge tuner set on the performance level and I get 25 mpg driving at 50-55 (msd "stacker 8" box is not plugged in yet)
- for real
(and that's driving up the "continental grade" if you will - going north here is up hill)
though if I push it at 60-70 mph my mileage tanks to 15-17 without downgrading the tune first
driving , the coil connectors are more notable than any air filter will be too
I have a stock 2000 Lightning airbox (80 mm) off my Lightning in my attic with a K&N filter. Don't know what it's worth. LMK if you are interested.
Anybody know where a new-in-box Ford OEM air filter box can be found for a 2000 L? Dealership mechanic ineptitude caused the lip on the lid of mine to warp.
I have an Air Box, a K&N filter and Motorcraft filter off of my 2000 Lightning that I would be willing to part with. Lat me know if you are interested.
Thank you
Thank you
Still available?
Still available?
When you hover your cursor over his avatar, you will see he hasn't been on in a little over a month. May have to wait a while.
1 - 17 of 17 Posts
