1 - 4 of 4 Posts
So I finally got around to unboxing my LiveWire TS+. I bought an OBD II splitter so I could keep my Aeroforce Interceptor plugged in along with my LiveWire TS+. At least, that's what I thought I could do.
It would appear you can't run the Interceptor with the LiveWire. Having the LiveWire turned on and turning on the Interceptor just displays a message that it can't communicate and turns off.
So, it's not possible to run two different devices from the OBD II Connector? I would think you would be able to with a splitter.
AntiSocial
A lot of devices are like this. The CANBUS can only move so much data. 2 devices overloads it and neither one gets the info it needs.
ODB2 connector also uses the same 20A fuse the ciggy lighter runs on.. gave me an issue .. thought my tuner/monitor had crapped out ..till I needed a smoke ..
1 - 4 of 4 Posts
