1 - 12 of 12 Posts
C&L ported upper intake manifold
Billetflow TB
these will be installed while the head gaskets are getting replaced and ARP studs[smilie=3g
and maybe a few interior goodies from Steeda! lol
Oil Field Trash
I need to get to work on installing some parts on mine:
Got the following laying around:
Punisher VB
Moroso Trans Pan
SD Trans Cooler with Braided Lines
Innovate Wideband
MP Idler Bracket
Metco Idler Pulleys
JLP CAI
BA 2800 MAF
D/S Loop
Accufab SBTB
Fluidyne Heat Exchanger
Bed Mount Fuelsafe Intercooler Res
LFP Dual Walbro 255 Kit
'97 Fuel Rails
Aeromotive FPR
Expy Console
Navi Pass Seat Pan
Punisher VB
Moroso Trans Pan
Innovate Wideband
MP Idler Bracket
Metco Idler Pulleys
JLP CAI
BA 2800 MAF
D/S Loop
Accufab SBTB
'97 Fuel Rails
Aeromotive FPR
Expy Console
Navi Pass Seat Pan
ya ya ya, we all know you always have parts laying around:potstirring
Oil Field Trash
Parts I have, time to install or drive the truck, I don't.
Oil Field Trash
i'm just glad you're FINALLY replacing that head gasket! Now you can enjoy your truck again as well.
Make sure you clean out the intercooler while ur in there, you're making waaay to much boost for a 2# lower
IF its really a #2.......remember what we talked about.....
So what did you talk about???? Are you still running the lower pulley i sold you? if so it is a 2lb lower.. By the way its about time to get your head gasket leak fixed. You going to have it running for the 20th?
Hello Jack! lol ya its still the same one, making 14 psi with the same setup. I won't be able to get it fixed in time for the meet, it'll have to be after I get back.
Hmm that is wierd. I am running a 8lb lower but only make 12lb because of my head port and exhaust system. Are your cats clogged or does your truck have an upper also?
Oil Field Trash
upper should be stock, ive never changed it. and cats shouldnt be clogged, they're Bassani high flow cats and are right at 3 yrs old now.
I'm guessing his intercooler is just plain filthy!
1 - 12 of 12 Posts
