1 - 12 of 12 Posts
Well I just ordered my new hubs. Having Aerospace make the new ones utilizing in a 5 x 4.5 bolt pattern so I can mount a set of 18x6 Alumastars up front on the truck. Once the hubs get here I'll be sending 1 off to Todd at TCE and seeing if he can work his magic on getting his 15inch kit to work with that hub and rim.
Long term plan is the run a couple different sets of wheels but the alumastars will be the smallest and I don't want to change brakes all the time. I'll keep everyone posted once parts start showing up.
Discussion Starter #2
537937
537938
537940
These showed up today.
Is the hub 2 pieces? Looking at the back side. One section (outer ring) is for the rotor to mount and the other section (inner ring) is where the studs mount. Just curious on that.
Discussion Starter #7
The Hub is actually 1 piece. The only thing that comes off of what you see is the small front cap on the end that screws on. As for price they def aren't cheap but I also had them make them in a different bolt pattern as well. 5x4.5 for different wheels that I want to run. They around $750
Discussion Starter #9
Looks like they are worth the cost. Post a short review about them next time.
I will as soon as I get them installed. I can tell you already that they come well packaged, appear but be of excellent quality. The bearings and studs come with them as well but they come with absolutely no instructions what so ever. Not they are a fairly easy pieces to figure out how to install just something to note that is all.
Did you have to give them any information as far as spindle sizes for your truck or did they know exactly what to make?
Discussion Starter #11
They new exactly what was needed for the lightning. Some of the guys here have there brakes already and in fact this was the same setup used on the Yeti I believe which is how they were able to fit the Welds up front which is exactly what I will be doing as well for a rim.
My uncle got a new Lightning project and he got some good plans for it. Bet he will like that hubs. I'll just finish installing the railings and hard tonneau cover and I'll share your photos here. Looking forward to your end results and reviews.
1 - 12 of 12 Posts
