Got an 02 that will crank no problem very strong but will not start. But if i leave the key in the on position for about 5-10 min when i try to crank it immediately starts. Once its on it runs 100% fine as long as i don't shut it off. If i turn the key off i have to wait again. If i remove fuel pump relay while its running it will stall, when i put it back in it will immediately start. The theft light is not flashing and the odometer is displaying mileage. I've tried wiggling the crank sensor wires both while running and while cranking with no difference. Anyone have any other ideas on what to check? Seems like its only when the ignition is turned to off that it doesn't want to restart. I've also tried swapping various relays with no results.
