stock block, stock crank, Mahle I beam rod's, Diamond zero deck coated pistons, reduced mass wrist pins, Diamond rings, TFS 185 heads, Crower 125# springs, Crower .580 lift 109 separation cams, adjustable cam sprockets, Cloyes chain kit, stock chain tensioners, TFS lash adjusters, Ford motor sports 4v rockers, innovators west stock size balancer, Melling oil pump, Fel Pro head gaskets, Accufab rear cover, all ARP fasteners
Line honed, bored .010 over, decked, rotating assembly balanced, Degreed, crack polished
So the first thing is the TFS head guides. There is plenty of stories about the machining of the guides being wrong and they prematurely wear out and drop valves.
I expressed my concern to my builder and sense the springs were being changed they would inspect. I was called at some point due to the TFS rockers that I supplied were rubbing on either the valve stem retainers and or keepers.
So it was built with 4v rockers to clear.
