More track passes.. Woohoo 9.10 @148mph
1270 Views 42 Replies 17 Participants Last post by  NettlesD
track rental today, it was a tad on the warm side. 🙃
Went 9.10 @ 148 with it 87 degrees and DA was about 2500'
  • Love
Reactions: 5
1 - 20 of 43 Posts
My man Marty 🏁🏁 WOW that was an awesome pass* on a good air day at that MPH you my friend have an 8 second lightning 🏁
congratulations on an awesome build *
my hats off to you Marty *
Job well done *
looking forward for that 8 second time slip 🏁
very happy for you my friend ❤
Marty you’re looking at 8.80s to 8.70s *
all you need is good Air *
See less See more
Reactions: 1
Awesome and congrats on a PB i think!! 😃
Reactions: 1
Congrats !
Jamie R.
03 Dsg Gen2
Reactions: 1
Congrats. Amazing
Reactions: 1
Very nice pass! How hard you turning the 3.8?
Reactions: 1
Thanks everyone!
6lb/9" lower and 3.5" upper pulley.
Damn that’s quick!
Reactions: 1
Thanks everyone!
Mid 20's boost?
Nice way to go Marty
Reactions: 1
Boost is about 28lbs, timing was at 15 degrees.
Reactions: 3
Sounds about right. Do you run a griptec upper pulley? My truck I swear will 60' a bit harder after I switched to griptec. Seems it cuts down on that little initial slippage. I also lock the converter in first gear.. not sure if Eric does that or not I can't remember.
No griptec, 10 rib setup.
I would still have them micro mill it.. cheap insurance. Though can't argue with current results either lol.
I mean it's the 4th pass on the setup. I'm sure it'll 60' better. As it's done better before
Reactions: 1
I know, but there is always room for improvement. At that ET he will be fighting for thousandths of a second and I believe a griptec pulley should be on everyone's trucks who race. Could be the small difference between a 9.00 and an 8.99 and I want to see him go faster.
Reactions: 1
Nice!!!
Looking forward to that 8 second slip!!
JJ
Reactions: 1
Holy balls that’s movin 🚀👍🏻
Congrats
Reactions: 1
Nice!!!
JJ
Yes JJ* I have also have been waiting for that 8 second slip*
I’m sure I’ll be getting that call real soon *
when all said and done he should been 8.80s to 8.7os*
He definitely has the (60) FT down *
If that was my Truck I would not touch a thing *
that pass told Me his setup is on the money *
to run that Et and That MPH in (87) hhhdegrees and DA of 2500 *
that truck is where it needs to be*
Marty don’t touch anything*
tire pressure/ shock settings/ Leave it as is*
the only thing i would change is How high you can come out on the converter*
on a good air day and a well prepped track if you come out harder you will go 8s*
Marty you definitely can drive just do everything the same exact way Except for the launch if the track can hold it*
If you want to make any changes that’s fine ,but do it after you run just as she’s right now *
Whatever timing you have.Whatever boost you have right now * (((((don’t TOUCH IT )))))
Marty what you forgot I’ll never learn, but I can tell you this*
I KNOW OUR (((((Lightnings)))))
wishing you all the best*
See less See more
  • Haha
Reactions: 2
1 - 20 of 43 Posts
