1 - 19 of 19 Posts
Moog Upper A Arms with 8k miles $103 shipped SOLD
Djm Lowering A Arms with 10k miles $246 shipped in SOLD
Ford ground pounder coils with 1 coil cut $70 shipped
Stock blisteins 70k miles $63 shipped-fronts only. no rears.
stock idler pulley bracket lightly polished $36 shipped
everything gets shipped fed ex. the soonest i can ship em is this sunday
i only ship to 48 states. pm or call me any time 773 443 7822
stock idler pulley bracket lightly polished $26 shipped
How much do the dim arms drop the truck?
The abandoner
they say 2 inchs. more if ya got lowering springs
lower arms alone are an advertised 2" drop, i think they provide closer to 3" tho..
My birthday is on tuesday! Hint Hint... (DJM lowers)
Are they already modded to bolt right up? Or do I have to break out the grinder?
the arms arent what need to be tweaked, if using these arms with spindles the spindles will have to be worked on.....besides you cant go any lower anyway lol
ok, so I have hotchkis springs with a coil cut and I think im a tad too low and I cant get it aligned, starting to cup the inner tread. Would buying your lower control arms and putting the stock coils back in put me at a nice 2'' drop?
Discussion Starter · #15 ·
well Iam not a pro but i can talk to ya about what i experienced....
in regards in alingment ya should get the upper a arms with camber bolts as this will slow down the wearing of the edges of your tires.
they will give you a 2 inch drop as the coil seat is lower.
ya should get the modified sway bar links from mad enterprise if ya gonna run lowering springs as you will be wearing out the bushing quickly
yep......time to open ya wallet! haaa
Get In The FastLane
About the lower control arms: Thinking of running 1" drop springs in conjuntion with the lower control arms. I heard the sway bar end links don't line up when going to lower control arms, is that what the mad enterprises end links do? I have cam bolts....How would my alignment be on this setup....
Discussion Starter · #17 ·
yes you would need his sway bar links. alingment will never be perfect when it's lowered more then 2 inches but will be the best it can be with the uppers and cam bolt kit. you could help your alingment if you get spindles
1 - 19 of 19 Posts
