is it just straight plug and play do you have to replace any harness or computers or can i just drop it in and goBoy do I know too much about this subject. A lot of people have done this:
-Basis: Pretty easy to do the swap if you need a new motor
You would need a Lightning spec rebuilt motor so that you get the Forged pistons, heads and connecting rods (and forged crank if you have an 02? or earlier). But dont just got a Lightning motor, then you'll have to deal with electrical harnesses. If you run the N/A pistons, heads, and connecting rods, youve got a ticking time bomb. There are a few people who have used full Lightning supercharger swaps, and includes everything you need for the supercharger part (midplate, heat exchanger, etc.). If you have the 4r70w, you'll also want to rebuild your tranny since it is only rayed for about 368 LB.FT.TQ.. Monster Transmissions sells a rebuild kit that males the 4r70w handle up to 638 LB.FT.TQ.. If you have the 4r100w then you wont need to rebuild it. If you have any other questions let me know.
You would need a Lightning spec rebuilt motor so that you get the Forged pistons, heads and connecting rods (and forged crank if you have an 02? or earlier). If you run the N/A pistons, heads, and connecting rods, youve got a ticking time bomb. There are a few people who have used full Lightning supercharger swaps, and includes everything you need. If you have the 4r70w, you'll also want to rebuild your tranny since it is only rayed for about 368 LB.FT.TQ.. Monster Transmissions sells a rebuild kit that males the 4r70w handle up to 638 LB.FT.TQ.. If you have the 4r100w then you wont need to rebuild it. If you have any other questions let me know.
Pretty sure the pistons weren't forged either but hypereutectic...might as well replace them while you're doing the rods.Wow there is some awful info.
You 100% do not need 97 Rails or an adjustable FPR.You will also need aftermarket fuel rails or 97 f150 fuel rails to be able to adjust your fuel pressure.
Good to know thanks. I was told I needed them to adjust base fp. I just assumed it was because my pumps don’t ramp and are wide open all the time.You 100% do not need 97 Rails or an adjustable FPR.
Wayne
You would need a Lightning spec rebuilt motor so that you get the Forged pistons, heads and connecting rods (and forged crank if you have an 02? or earlier). But dont just got a Lightning motor, then you'll have to deal with electrical harnesses. If you run the N/A pistons, heads, and connecting rods, youve got a ticking time bomb. There are a few people who are selling used full Lightning supercharger swaps, and includes everything you need for the supercharger part (midplate, heat exchanger, etc.). If you have the 4r70w, you'll also want to rebuild your tranny since it is only rayed for about 368 LB.FT.TQ.. Monster Transmissions sells a rebuild kit that males the 4r70w handle up to 638 LB.FT.TQ.. If you have the 4r100w then you wont need to rebuild it. If you have any other questions let me know.
lengthen two wiresis it just straight plug and play do you have to replace any harness or computers or can i just drop it in and go
Like a walking encyclopedia of Lightning knowledge, man...I just learned something as I had no idea they were actually forged, albeit not a great forged piston, but forged nonetheless.Lightning pistons are forged. Not quality forged like the cobra. But they are forged. They're 4032 forged aluminum. They're failing is they're thin and can't handle rpm. But are good to 600ish
Like a walking encyclopedia of Lightning knowledge, man...I just learned something as I had no idea they were actually forged, albeit not a great forged piston, but forged nonetheless.![]()
