Due to my needs, I run a Killer Chiller & a Stock Heat Exchanger.
Its plumbed like this:
Tank > Pump > 3 way valve
..................... <- One direction goes to the Heat Exchanger
..................... -> The other direction goes to the Killer Chiller
Both sides meet a "T" fitting > intercooler > tank.
This setup allows 'One or the Other'....you never want to employ both simultaneously.
When running the Killer Chiller the fluid will always be colder than ambient...even post intercooler...so having the fluid pass through through the heat exchanger at any point will actually absorb the ambient "heat" making the system a great deal less efficient.
A block off isn't enough, the heat exchanger will absorb radiant heat and condensate, use a 3 way.
I decided to go this route instead of deleting the heat exchanger completely for 3 reasons:
-I daily drive the truck
-It gets HOT here in South Louisiana
-The traffic sucks
On days in July and August when its 100-103* and I know I'll be stuck in traffic for an hour or more, I flip the 3 way valve and the fluid only goes through the Heat Exchanger.
This allows ICE cold A/C in cab and no worries of overheating the engine by loading up the condenser so heavily and not getting enough airflow in traffic.
It really is a no compromise setup when executed properly.
I can race back to back to back with the KC on, or I can flip the valves and Idle in 100+ degree temps with the a/c wide open just like stock.
