281 - 300 of 328 Posts
local painter
Discussion Starter #281
Installed the I/C lines do the bed mounted tank. Hard to tell from the pics but they are routed tank to pump inlet. Pump outlet to HE to I/C back to the Res.
“Looks like the “Buster” was helping, he did run back to the fort....” haha
Reactions: Leeproctor83
local painter
Discussion Starter #283
Added fuel drain valve and let it down off the jack stands so I can finish installing what’s left.
Looks like you're on the home stretch. Bet you'll be glad to finish that up and get out there and smoke the tires.
local painter
Discussion Starter #286
Nice work Kenny! How did you plumb your ethanol sensor in?
My custom stock fuel hat has 2 -6an feeds and 1 -8an return. So it was easy. I seent that thing you used. That’s a nice piece. Not needed for my application tho.
Reactions: NMSVT
Looking good homie.
local painter
Discussion Starter #288
Got the o2 sensors.power steering pump. a/C pump. Wideband. Alternator. Trans wire harness installed. Also lower intake and midplate.
Getting close 😁
local painter
Discussion Starter #289
Fuel injectors, rails and FPR on. Blower,plenum and TB on. Fancy new TB bracket on. And new starter solenoid relay thing an Coil packs.
Reactions: P_Franko03
11 second street truck
2001 Ford Lightning
We have the same rails and injectors. Twinsies
local painter
Discussion Starter #291
Now I just need to install the hood. Fluids and Give it a bath. Also an updated tune from @Modular Big Bore Stroker for 93 and E85
local painter
Discussion Starter #292
Started it for the 1st time today 😁
local painter
Discussion Starter #293
I’m particularly proud of this provision I came up with for mounting my Fuel lab filter in the engine bay half ass cleanly. I used an I/C pump bracket from
a GT500. It’s the cylindrical rubber piece around the filter. It has a flat metal bracket thst fits up nicely where it bolts up to the radiator support.
local painter
Discussion Starter #295
Because working on them is more fun than actually driving them I went ahead and took the blower off. I’ll take the lower intake off also and fix a leak. 🤦🏻‍♂️
local painter
Discussion Starter #297
Coolant crossover pipe on the RS.
local painter
Discussion Starter #298 (Edited)
I think it’s fixed. I drilled and tapped the RS deeper. And used Pipe thread sealant this time. Feeling confident it’s fixed. If it leaks again I’ll be having them Tig welded in.
Reactions: utlong31
I hope your luck is better than mine. I took it off twice and still have a very small leak. It will get welded next time it’s off, maybe in 10 years. I’m not certain if it’s leaking from the fitting or the gasket seal area. I just noticed it under the truck after it’s been sitting. Thankfully it’s just a small drip. Last two times it would fill up like yours. Good luck hopefully you got it fixed. Your truck looks amazing.
local painter
Discussion Starter #300
