261 - 280 of 344 Posts
I made sweet n spicy 🌶 and jalapeño flavor. They turned out great.
nice
I need to get on it and make some!
I want to experiment with my own spices and such
local painter
Discussion Starter · #262 ·
Clocked the thermostat housing so my radiator hose no longer needs trimmed. I just had to file the holes a bit with a 1/4” angle grinder with a small carbide burr. The new Tim hoses will be here Monday.
I c
I heard Tim does radiator hoses. Is that what you are talking about. Different color options.
local painter
Discussion Starter · #264 ·
I think it’s just a stock rad hose with fish net on it 🤷🏻‍♂️ I’ll let you know Monday when it gets here. Also he’s sending me a coolant crossover mod and new heater hoses that work with the crossover. So I’ll have my original Tim heater hoses for sale.
local painter
Discussion Starter · #266 ·
I've never heard of the hoses needing clocked
the JPS midplate makes the radiator hose unable to go all the way onto the thermostat housing. So we clock the housing slightly for clearance.
local painter
Discussion Starter · #268 · (Edited)
Tim coolent crossover and upper rad hose came today.
local painter
Discussion Starter · #270 ·
Mr David Boyer @dboyer made me these killer poly motor mounts.
The material is a shore hardness 80A High Performance Polyurethane liquid. He used a 304 Stainless bushing to avoid the bolt getting rusted in them. It Completely replaces the the stock 60 shore hardness rubber bushing that is made for comfort not high performance. They make a 90 durameter liquid, but it is pretty close to a solid engine mount.
local painter
Discussion Starter · #271 ·
Next is install Tims hoses.
Then drop it in finally.
Slevin
Those heater hoses are a bitch to install but so worth it
local painter
Discussion Starter · #273 ·
Its the coolant crossover with heater hoses. Half of it is AN fittings. I already have the original tim heater hoses.
local painter
Discussion Starter · #274 ·
Did the crossover today.
Reactions: Painless Autoworks
local painter
Discussion Starter · #276 ·
Kenny, where did you get the fitting that screws into the left side of the intake?
I got the kit from Tim. I had to cut about 3 threads off that were sticking out the bottom
local painter
Discussion Starter · #277 ·
It puts the engine in the hole
Reactions: Boss Hoss
local painter
Discussion Starter · #279 ·
Got the longtubes installed today.
Tired old Dynatec
Reactions: Dusten
local painter
Discussion Starter · #280 ·
Got the trans in today!! And the rest of the exhaust hung up there. And routed some fuel lines and coolant lines. Installed the ford performance starter.
