The knock sensor is installed in our trucks. It appears to be wired up and there is circuitry in the computer to use it. It is turned off by Ford as it has trouble distinguishing other noises and vibrations from the blower or whatever and pulls timing even when it isn't needed. Is this true?
If so, then the computer has the capability to use a knock sensor if the sensor could be trusted, right? There is a prominent company that has a unit that could go between the factory knock sensor and the computer and filter the messages and determine whether it is detonation or not and then when it is that is passed onto the computer to allow it to handle the issue. Since the main problem is in trusting the sensor, if this can make the sensor "trustworthy" then it should be a viable alternative. This system has the ability to only retard a single cylinder or cylinders that are having a problem. There isn't a sudden cutting of all power or a big delay to get it back, it is virtually instantaneous. But for it to work the circuitry must be able to be turned on in the computer through software, which I believe is available.
Any thoughts? Oh he is working on an 8 coil on plug system but he already has a simpler (and maybe less expensive) solution if the above is true.
Jody
__________________
Jody
__________________
