1 - 20 of 41 Posts
My nephew has been using my adapter for my 10# ring and he taking it to be worked on today...He is going to remove it and I will be able to put the ring on and belt the bitch up...Also, need to change the fuel filter.
Mr. Crossfire
Looking good Dave, happy for ya
Those are DMR bolts, the ones that Garrett used to sell...The vacuum line is Hose Candy and all you have to do is twist it apart when it needs removed, then you can screw it back together.
Me likey:smt023
:bigtu:bigtu looks amazing!
might want to put a small clamp on that hose candy red hose on the front right of the upper intake.... high boost can blow it off of there; it happened to Neil at LF7.... truck wouldn't make boost. Good thing JL was there, we had to run with my L back down the return lane and reconnect it; then he was back in business!
What are your goals??
Definitely following this build/ thread; keep it updated would you?:cheers
Looking Good crewsy.
:bigtu:bigtu-Bob
Discussion Starter · #15 ·
I guess my goals are for Jerry to be dependable, and to just be able to go to the strip and run 11's the way he got there...I would also like to get close to Jim's 10.89 on a race tune...This engine was designed to be able to run nitrous by the type and gapping of the rings, so I have some plans that way also...I just want the truck to be like Jim's, drive it to wherever I want to and race him...Hopefully, after I recover from this build and get some money together, I would like to add a steering rack and a few more weight saving mods.
Building a fast catfish!!!
Hope the valve covers don act like tfs
Sent via my damn droid.
Discussion Starter · #19 ·
Thanks Jim, I appreciate your help and all the knowledge that your share on this site...I am trying to make Jerry like your truck where I can drive it to the track, and then drive it home with the AC working and listening to some tunes.
Enjoy all your hard work Dave! I'm sure you'll have a beast on your hands.
1 - 20 of 41 Posts
