1 - 6 of 6 Posts
What symptoms with this transmission would indicate I have the shitty transmission, and how do the symptom manifest itself prior to failure? Can't win for losing here. The more I learn the worse it gets.
Discussion Starter · #2 ·
70, 000 on the clock.
Just did a full service with Punisher Valve Body, fYI, no test drive yet.
No abnormal metal on the pan pull, 70K trans.
10 second street truck
A j1 fails due to a mechanical diode. There are no precursor symptoms. It's basically caused by a very specific set of circumstances.
Once the failure occurs you'll know. Because second gear will be gone.
In second gear if you go wot and lift and get back on it while still in second, that will cause it.
1 - 6 of 6 Posts
