1 - 17 of 17 Posts
11 second street truck
I have been doing some reading on the vampire system, and am intrigued.
My truck is a DD on a stock block, ported eaton, 6lb lower and 2.83 upper. It makes about 15-16lbs of boost depending on weather. Tune is safe with 11.0-11.3 AFR at WOT. Makes ~425rwhp and runs 110 in the quarter with street tires on it and a tranny that died 2 weeks later.
I am deployed now, but the plan was to swap out a stock upper and lower the boost after deployment and have it retuned just to make it "safer".
However the Vampire isn't much more than the pulley and re-tune, and would allow me to keep my power level that i currently have.
For those of you that run them, which path do you think is the safer route?
Go with the J&S.
A safe tune and low boost is great as long as nothing ever goes wrong like a bad injector, fuel pump, pressure regulator, clogged filter, bad tank of gas, some idiot in a stock Silverado trying to play with you when it's 20* outside, etc......
x2 on going with the J&S
I'm hoping to install a J&S and a 2.80 on my snake bite equipped Eaton (this spring) to push it over 18# on a stock long block
You can't get safer than you will be with the Vampire...Like Doc said it will compensate for a variety of situations that can happen.
Im at 15lbs with the MP on my stock block. Im not getting as much as I hoped I would at 15lbs. I'll probably be bumping it up to 18lbs in the spring.
Glad I got a J&S! :bigtu
I see it activate here and there, dont know whats causing it when it does, nothing feels different when it does. But Im glad its doing its thing!
Discussion Starter #7
thanks guys, this is what i was thinking.
sonic, i may pick your brain when i get back on the install, seeing as you are local-ish.
No problem. Its pretty easy. I went ahead and got the MSD harness for it. A bit more wiring under the hood, but its not that noticeable, and made it plug and play so I didnt have to splice all the coil wires
Order direct from MSD, part number ASY 29003. If they ask, it's a replacement harness for the 8734 "2 Step".
Last price I was quoted was $114.20 plus shipping.
I have been considering this to protect my considerable investment. Need the money tree to have a good growing season. Spent a fortune and still need to spend more.:smt101
My truck is faster than your Vette
What exactly does the vampire system do?
with a good tune, proper timing level and good 93 gas youll have no problems. I ran this much boost with a 75 shot on top with my stock block for years on pump gas.
1 - 17 of 17 Posts
