Got in the truck this morning, hit the lights and the instrument panel is dim. Not all the way off, just dim. Switch is up and it actually dims it like it should when you adjust it. Searched and found there is a solder point on the instrument board that comes loose. Wonder if this would help me???
Input please
Thanks
Usually the solder point is for when the odometer goes out.
Okay.... Mine is the whole damn dash. HVAC and column boost gauge lights are normal though. Just the instrument panel.
More searching for me :)
Thanks
no dice on this.... wonder if the switch is going bad. Rheostat type switch.... Hmmmmm
Figured it out... I think. Sunday was a big rain day here in South Louisiana and I left my windows cracked a bit (as always). I have the window vents, but the humidity was thick. Thinking the humidity had something to do with it because it is back to being bright.
