1 - 6 of 6 Posts
HemiLOL
just removed the accufab sbtb to sell it and reinstalled the stock throttle body i was given when i bought the truck. the tps, according to my diablo is 1.00. thats as low as i could get it, no lower at all. truck will start, idle to about 1500 and then die. if i try to keep it running it tries but chokes alot. any ideas? i didnt unhook the battery during install. i also did not remove the air intake, i just moved it to the side.
Senior Member
Is it tuned? Or just a tune that came with your diablo...
HemiLOL
its just the canned 93 tune
check the hoses going to the intake elbow are connected (on Both ends of the hoses), make sure your maf is plugged in
might also want to disconnect your battery
HemiLOL
yeah i unhooked the batt for like 5 mins, but ive had it unhooked the last 30 mins now. ill retry in a few. maf is not disconnected, i didnt d/c it, i just moved the flexable hose down some. im going to unplug the maf sensor and reinstall it just incase though.
may try to reinstall the accufab and see if my problem goes away, if it does im guessing my stock tb has problems. i have the stock tb from my 00 L also sitting here
1 - 6 of 6 Posts
