Stock return line?
How many ohms is the resistor showing?
Not sure but jumped the resistor and no change. Finding that the fuel pump relay has no ground on the coil side of the relay which isn't sending power to the inertia relayStock return line?
I'll be getting a reg and rail soon. But does it constitute for the prm(rewire module for pumps) to not be recieving more then 6v at key on? The coil circuit of the pump relay is not grounding there for sending the 12v to the inertia relay then to pump harness?You need to put the wiring back to stock, till you get a FPR installed.
Voltage was checked with the fuse out at the box terminals. Fuse in has 12v...Replace the fuse that has different readings.
Yes with the fuse out measure voltage at the terminals. Plugged in it equals to 12v both sideDidn’t you say fuse 18 had 12v on one side and 7v on the other side?
