1 - 9 of 9 Posts
Good book to help suplement the SCT ProRacer Manual (and alot less that $75)
"How to Tune & Modify Engine Management Systems" by Jeff Hartman
I picked up a copy at Borders for $29 only to find it online for $19.
The book give very good, easy to understand outline on the sensors, actuators and controllers for engine management and control. It is a heavy read - quite a lot to absorb. I've made it about 1/2 way though and, so far, highly recommend it for general ECM and component function understanding.
Herb
Yeah, the $75. manual is mostly covered in the help section included with the Pro Racer, but there are some helpful tables for running different injectors, etc. plus some more in-depth info.
That book sounds good Herb and would be a very good idea for anyone considering doing their own tuning who isn't familiar with EFI operation. Thanks for the tip! :smt023
Jody
Jody
Is this help section on the dick or program as I have not opened anything yet but to have it openable?
Welcome Cal - glad you found us!!
I don't have the software yet, so I can't comment on what it comes with, but the book is an actual spiral bound, 120 page book with tuning tips and software usage tips. It's expensive at $75, but it has good info. Maybe one of the other guys can comment on how well it relates in their use, as I am still gathering info.
Here are a couple links - I scanned the cover, the table of contents and a random sample page, so you can get the 'flavor' of it.
http://www.lightningrodder.com/gallery/displayimage.php?album=lastup&cat=10050&pos=0
http://www.lightningrodder.com/gallery/displayimage.php?album=lastup&cat=10050&pos=2
http://www.lightningrodder.com/gallery/displayimage.php?album=lastup&cat=10050&pos=3
http://www.lightningrodder.com/gallery/displayimage.php?album=lastup&cat=10050&pos=1
Good luck,
Herb
cal50 said:
Herb 101
Can you change the maf  through the program or do I still have to install that maf extander?
THANKS,CAL
You can change the tune for whichever MAF or extender you plan to run, but it doesn't replace the bigger MAF/extender. If you're maxing the stock MAF you'll still have to make a change.
Jody
1 - 9 of 9 Posts
