For those that don't know SVT_KY passed away from cancer.
These links no longer work, but we are working on a new how-to thread much like the one he did for us here. RIP Cliff.
Please be patient....
Thanks,
MPORTETR
One stop shopping for all your Lightning procedures ...
If you want something added, drop a note here ...
NOTE: AS OF 26 AUG 2009, the ENGINE SUBASSEMBLIES section is verified as existing AS IT IS. (GOOD LINKS)
If you can't see it, it's your Acrobat reader that needs updating. - Cliff
EDIT History
New Stuff = [smilie=wa]
March 2006
Added Front Caliper Bracket [smilie=wa]
November 2005
Added Suppercharger R&R [smilie=wa]
Engine Section
Main Engine
Remove Engine
Remove AC Core
Remove Water Pump
Cooling Fan Removal
Engine Assembly
Engine Disassembly
Engine Subassemblies
Supercharger Section
Inspect Supercharger Coolant
Drain, Fill and Bleeding Supercharger Coolant
Flushing Supercharger Coolant
Lower SC Pulley Removal
Super Charger (Charge Air Cooler) R & R
Steering, Suspension and Brakes Section
Alignment SpecsFront Suspension and Brakes
Miscellaneous SectionWiring Diagrams Vendor Instructions
Thanks,
MPORTETR
EDIT History
March 2006
November 2005
Engine Section
Main Engine
Remove Engine
Remove AC Core
Remove Water Pump
Cooling Fan Removal
Engine Assembly
Engine Disassembly
Cooling Systems Section
Transmission SectionSteering, Suspension and Brakes Section
Front Disc Brakes
Caliper Anchor Plate
Front Wheel Bearing Remove and Replace
Front Sway Bar R and R
Upper Control Arm R and R
Rear Suspension and BrakesCaliper Anchor Plate
SVT_KY Tutorial on rear pad R&R
Rear Suspension Torque Specs
Rear Pads
Rear Rotors
Rear Caliper
Rear Dust Shield
Rear Caliper Piston
Rear Brake Adaptor
SteeringRear Suspension Torque Specs
Rear Pads
Rear Rotors
Rear Caliper
Rear Dust Shield
Rear Caliper Piston
Rear Brake Adaptor
