1 - 20 of 41 Posts
For those that don't know SVT_KY passed away from cancer. I'm working on a new how-to thread putting my twist on the one he did for us while he was here. RIP Cliff. Please be patient....
Thanks,
MPORTETR
One stop shopping for all your Lightning procedures ...all links are in Orange.
If you want something added, drop a note Here ... :bigtu
Abbreviations & Acronyms(Thanks BgStew6)
UPKEEP
General Maintenance
Engine Section
Intake
TB Adjustment(Thanks KwikSlvr)
Dual Catch Cans w/Eaton(Thanks SHOKDU)
Main Engine
Idler Bearing R & R(Thanks Ride The)
Idler Bearing R & R(Thanks ZZZZap)
Cleaning Up/Uncluttering Engine Bay(Thanks YUSOSLO)
Engine Assembly(Thanks DolSVT00)
Time a 5.4(Thanks MMShaggy)
Changing Lifters
Caged Pulley Removal(Thanks oldtimer)
Lower Pulley(Thanks BigStew6)
Spark Plug Change(Thanks usafdrew)
Injectors DIY(Thanks cacric)
Changing Fuel Pumps w/o Dropping Tank(Thanks nitrous347)
Walboro 255 Pumps(Thanks SVThomas)
R&R Starter(Thanks dsg2003mach1)
Torque Specs(Thanks BgStew6)
Supercharger Section
Supercharger Proper Torque Sequencing (Thanks BgStew6)
Boost Actuator Adjustment (Thanks Rob!)
Supercharger R &R (Thanks Rob!)
Snout Rebuild(Thanks BgStew6)
Snout Rebuild (Thanks INFAMOU$)
Eaton Rotor Removal
Rear Case Bearing R&R(Thanks TennTechMan)
Cooling Systems
Cleaning Intercooler Pump(Thanks BgStew6)
Intercooler pump $6.00 fix(Thanks -=TWITCH=-)
Fill and Drain Fill Cooling System
Flushing Transmission Fluid (Thanks Everyone!)
Heater Core Replacement(Thanks 02SVT Lightning)
Exhaust
Headers & Catback(Thanks LightningDan and Darren5.0L)
Transmission
Building a 4r100(Thanks Dirty DOg)
TQ Converter(Thanks DirtyDOg)
Jackpot and Rearend
Rear Diff Cover R&R(Thanks BgStew6)
Rear Axle Seals(Thanks Dusten)
Harley Carrier Bearing(Thanks nitrous2fast)
Checking & Adjusting Rear Pinion Angle(Thanks BigStew6)
Checking & Adjusting Rear Pinion Angle (Thanks Ride The)
Steering, Suspension and Brakes Section
Clunk Washers & Cam Bolts(Thanks oldtimer)
Lightning Alignment Specifications
Front Suspension and Brakes
Hydroboost Upgrade (Thanks funta!)
Season Rotors and Bad Pads (Thanks BgStew6)
Fix Spongy Brake Pedal (Thanks BgStew6)
Front Wheel Bearing Remove and Replace
Front Sway Bar R and R
Upper Control Arm R and R
Rear Suspension and Brakes
Rear Shocks(Thanks SWThomas)
Removing Rear Leaf Springs(Thanks mrcarbine)
Rear Sway Bar(Thanks mdan575)
Broncobeater Long Bars, Driveshaft Loop, & Panhard Bar Install(Thanks Broncobeater)
DIY Line Lock Install
Needed
R&R Rear Suspension
Rear Rotors
Rear Caliper
Rear Dust Shield
Rear Caliper
Piston Rear
Brake Adaptor
Steering
Needed
Overview
Inner Tie Rod Ends
Outer Tie Rod Ends
Tie Rod Adjusting
Sleeve Sector
Shaft Drag Link Sector
Shaft Arm Idler Arm R and R
Electrical Section
Changing Headlight Bulbs
Headlight Adjustment
Test Coil Packs(Thanks BgStew6)
Adjusting TPS
Instrument Panel Removal (Thanks Ride The)
Instrument Cluster Removal (Thanks BgStew6)
OD Quick Fix(Thanks BgStew6)
Cluster Light Fix (Thanks BgStew6)
Programming Keyless Entry Pad & Remotes(Thanks BgStew6)
qurtrn10)
Needed
Power Steering R and R
Wiring Diagram
Testing Fuel System Resistor (Thanks BgStew6)
Simulate Factory Narrowband with Innovate LC-1 (Thanks rman)
Remote Fuel Sending Unit(Thanks BgStew6)
Fuel Filter R&R
Door Panel R&R(Thanks toddslightning&Rob)
Door Panels & Handles(Thanks JROC)
SPEED
A list of performance mods
Battery Relocation 1(Thanks S¦ck)
Battery Relocation 2(Thanks Midget)
Battery Kill Switch(Thanks banks)
Trash Can Mod(Thanks Redrum)
MP Big O TB(Thanks ChrisLightning)
Lower Pulley (Thanks BgStew6)
KB 2.3 Install(Thanks BgStew6)
DIY Efan Kit(Thanks baggedsvt)
Deleting AC Compressor(Thanks Got Boost)
MMCustomworks AC Gauge Pod(Thanks Uncooked)
Killer Chiller(Thanks 00SVT)
Hanger Install w/o Bed Removal (Thanks Hammer101)
Lakewood Slappers(Thanks Dash808)
Longbar Install(Thanks broncobeater and redrum)
ABS Delete(Thanks MY1999SVT)
Adding SD Cooler(Thanks SWThomas)
Valve Body(Thanks Rob)
Stripping Rotors(Thanks exracr)
Supercharger Home Port (Thanks Soccman!)
Tensioner Mod & Idlers(Thanks oldtimer)
Weight Reduction(Thanks S¦ck)
#4 to #8 Cylinder Lower Manifold Cooling Mod
Meziere Pump Bracket(Thanks chrisheltra)
SCT Downloading and Dataloging(Thanks Stoffer)
STYLE
Looks and Appearance Mods
Plastic Dip'n your Wheels
Bumper Gap Mod(Thanks tylerallancars)
Grill Mod(Thanks oldtimer)
Headlight Lens Restoration( Thanks #529)
ABS Interior or Exterior Plastic Repair (Thanks Tex Arcana)
Keyless entry HID mod (Thanks BgStew6)
Dying Interior Black(Thanks Infamou$)
EATC Conversion(Thanks)
Heater Switch Color Change(Thanks BS Racing)
Power Sliding Rear Window Mod(Thanks qurtrn10)
Solid Rear Window Conversion(Thanks SHOKDU)
Radar Detector Hard Wire(Thanks SKY KY & BgStew6)
Recovering Visors(Thanks Cyclone)
Removing VHT Night Shade(Thanks cowsrkool)
Seat Mod and Expy Console(Thanks fastmiteclip)
Shaved Tailgate(Thanks Patman03sprcrw)
Tailgate Retention Mod(Thanks Tigator)
GM Windshield Squirter Mod(Thanks oldtimer)
Lighting Section
Exterior Lighting
HID's(Thanks 65fastback2+2)
Depo Projection Heads w/ HID's(Thanks cxm)
Interior Lighting
Interior LED conversion(Thanks castellscl)
Fog Light Mod(Thanks everyone)
Predator Hints, Tips, and Manual(Thanks BgStew6)
Load an Email Tune(Thanks Stoffer)
Miscellaneous Section
Dual Resistor Mod(Thanks lkatya)
Fuel Pump Track Switch Mod(Thanks Ride The)
EGR Delete (Thanks CHIZ!)
PCV Delete(Thanks BgStew6)
Trailer Brake Controller(Thanks BgStew6)
Boost Bypass(Thanks Rob)
Clearing the P1000 Code (Thanks BgStew6)
Instrument Cluster Test Mode (Thanks BgStew6)
Deactivate Auto Lock (Thanks BgStew6)
Program Home Link System (Thanks BgStew6)
Use Sea Foam (Thanks BgStew6)
This is just the beginning so bear with me till I can get it organized lol. I'm trying to add a few links weekly!
Discussion Starter · #2 ·
Any Suggestions?
Thanks Guys! Hopefully I can make the search button obsolete in this section lol.
headlight knob
MPORTETR,
Your how to manuals are excellent, I am however having trouble getting the headlight knob off, I've tried the toothpick as recommended, as well as a host of other items, but to no avail, are you aware of any tool that is idiot proof that I could use,
Thanks in advance. .
MPORTETR,
Thanks Bro! Here's a subscribed link I had that shows a few more pix of the unit but It's been so long since I messed with mine that I've forgotten what I used...seems like it was 10g solid copper wire...
Another Fog Mod Thread
Upgraded In Tank Fuel Line Kits!!!!
Add this to the brake/wheel bearing section!!
Here is the proper way to set the wheel bearing torque on your 4x2. When I replaced the wheel bearings on my 1999 L I used these steps:
With the brake disc and hub on the spindle, and the wheel bearing installed and the spindle nut on just hand tight,
1) While rotating the disc, tighten the spindle nut to 30 lb/ft (40 Nm)
2) Loosen the spindle nut two turns, making sure you do not let the disc come off the spindle
3) Rotate the disc and tighten the spindle nut to 17-24 lb/ft (23-34 Nm)
4) Loosen the spindle nut, again making sure not to allow the disc to start coming off the spindle
5) Tighten the spindle nut while rotating the disc to 17 lb/in (2 Nm)
6) Install the nut retainer, making sure you align the holes with the holes in the spindle nut, and install the cotter pin. The nut retainer has various hole alignments, allowing you to line them up without having to loosen or tighten the spindle nut.
By using this procedure, you are pre-loading the wheel bearing to its proper specs with the two steps of torquing, and then getting the final torque of 17-24 lb/in (2 Nm). Note that the last torque is INCH POUNDS, not FOOT POUNDS. You might have to borrow the torque wrench from Auto Zone or elsewhere that loans tools. Not too many "home" mechanics have torque wrenches other than Ft lbs.
I repacked my bearings after 20,000 miles and before removal I checked how tight the nut was, it was loose, I repeated these steps after repacking the used bearings and all is good!!
:bigtu
Reactions: MPORTETR
Discussion Starter · #12 ·
Post me some pics to go with it and it will be! What's a spindle? Spindle nut? Hub? Is that that thing that keeps falling off my Honda and rolling down the road? Gotta have some pics for some guys if you know what I mean lol. Very nice write up!!! :bigtu
Reactions: 01RedLightning
I doubt I'll get pics anytime soon, maybe someone else that has free time!!
Discussion Starter · #14 ·
Just giving you a hard time Ryan! Good info and I'll see if I can find some pix if you don't have any. :cheers
Bet you were born naked, you SLUT!
Best way to pull the motor? lol
The GOLD RUSH!
My maint (new owners start here) thread needs to be added under general upkeep. I get WAY too many pms about it still asking where it went since its not on this list and it has fallen down in the how to page.
Blue is the fast Color
Replacing Lightning pedal covers with HD covers.
I have heard that early on some guys were replacing there Lightning pedal
covers with the HD Covers. So far I have replaced the E-brake and the Brake
pedal cover, now I am faced with trying to replace the accelerator pedal with
the HD cover. Not as straight forward as the first two.
This is a totally different set up. I am really stuck between doing or not doing
this part of the mod.
Anyone have any ideas how to go about this with out changing all of the
remaining accelerator mounting bracket.
HELP
Thanks :smt021
I see injector cleaning how-to. What about a how-to for replacing injectors?
1 - 20 of 41 Posts
