Figured I would start a new thread since this is no longer about quick detailer. Sorry for the length, clay bar, iron x and finishing up with wax applied by hand is as far as I have ever gone.
I have purchased what I believe is everything I need to do a novice paint correction:
pc7424xp
meguiars 5" back plate DBP5
meguiars 5" cutting pad DFC5
meguiars 5" polishing pad DFP5
meguiars 5" finish pad DFF5
33.8oz concentrated carpro immolube for clay bar/quick detailer
ultra fine clay bar
iron x
spray bottle to mix immolube in and apply
distilled water to mix immolube with
meguiars ultimate compound
meguiars ultimate polish
obsssd paint seal
(3) chemical guys el gordo 16x16 mf towels
(3) chemical guys workhorse 16x16 mf towels
(3) of these https://www.carpro-us.com/microfiber-towels/carpro-shop-towel-24-x-16/
and of course I purchased a new roll of paint masking tape
Anything else I am missing? I would like to attempt a paint correction this week. Someone please correct me(especially Merlin or anyone else that is really into vehicle detailing) if I am wrong in any of this.
The truck hasn't had wax applied in 3 years or more. Do I still need to wash with dawn dish soap or can I just use my normal car soap?(chemical guys Mr. Pink)
Do I work in this order?
step 1) wash truck w/2 bucket method (dawn dish soap/mr pink,do i need to dry it?)
step 2) spray truck down with iron x to loosen up iron contaminants, let soak
step 3) rinse off the paint thoroughly, making sure to remove all iron x
step 4) clay bar the paint with clay and immolube (do i have to rinse after this or dry the paint?)
step 5) mask off all plastic and rubber trim
step 6)with the pc7424xp,use meguiars ultimate compound and DFC5 cutting pad to remove swirls and scratches.
step 7) use the DFP5 polishing pad with meguiars ultimate polish
step 8 ) use the DFF5 finishing pad with obssssd paint seal
****Do I use the immolube and a mf towel to remove every compound after I am done?**** This will be done outside under a carport on a light windy day,7mph or less. Knowing cleanliness is a key factor, do I spray each panel down with quick detailer prior to any paint correction/polishing or is that being too anal?
Do I have to buff off the sealant with a mf towel like wax or is sealant different? When do I know the ultimate compound and ultimate polish is done?(i believe this is called flashing?) Do I have to prime the pads and if so,how do I do this? How much compound/polish/sealant do I use on the pad?
Anything else that I haven't asked/covered? Immolube gets diluted 20% immolube / 80% distilled water if I am reading the ratio's correctly?https://www.carpro-us.com/deep-cleanse/carpro-immolube-1-liter-34oz/
How do you guys buff/polish areas that are tight like where the fog lights are? Do you polish over the handles or do you avoid them? Would removing the bed caps make life easier?
Thanks everyone, sorry for the long thread and tons of questions. But this can get expensive quickly.
pc7424xp
ultra fine clay bar
iron x
obsssd paint seal
