Dial-Ur-Boost 2LB Upper Pulley System, by South Florida Pulley Headquarters. "I HIGHLY RECCOMEND IT".
This System adds Performance, ET, and together with the SFPH 4lb Lower Pulley I run it gives me much adjustability for changing
seasons and the different set-ups I run.
Bought from:
http://www.southfloridapulleyhq.com/
This is one of the easiest Mod's you'll EVER do
Simply remove your Pulley Belt (using a Std 1/2" Drive Breaker Bar)
Remove the Bolt in the Center of the Upper Pulley (8mm if I remember ?)
Use a Puller Tool (I bought mine from SFPH also)
And Remove the Factory Upper Pulley
Then Use the same puller tool, "but in a different configuration"
And PRESS the Dial-Ur-Boost Hub onto the Eaton Shaft
It'll Now look like this
Then simply install the Pulley of your choice "with 4 Allen Bolts"
Re-install the Center Bolt (never has to come out again to swap Pulleys)
Put your Belt back on
AND WAM, YOU’RE DONE
Start to finish in @ 1/2 hour no prob
Bought from:
