Purpose of a boost bypass kit
The purpose of a boost bypass kit is to supply continuous boost from your supercharger when exceeding acceleration limits set by the factory. When acceleration exceeds factory limits, the boost actuator solenoid actuates the boost dump valve, relieving the superchargers pressure until the truck is shut down and restarted. With the boost bypass modification, you will now be able to keep your boost at the maximum level when under WOT usage. The term “boost bypass” is a bit misleading by all those dealers advertising this kit for a price. Its true name should be, WOT bypass eliminator kit . . . This modification does not effect normal engine operation and is designed for modifying boost bypass at WOT only. (WOT= wide open throttle)
