1 - 20 of 30 Posts
i'm gonna get some supercharger oil from the local gm dealership for my eaton... how much do i need?
also can anyone tell me direct replacements for stock plugs?
buy 2 bottles, use 1.5, approx 6 oz IIRC
Ford Certified Technician
basicly from empty fill it up to the bottom of the filler hole..... or untill it starts to just dribble out a little bit of the filler hole.
bout a bottle and a 1/4 and its full roughly
Building a fast catfish!!!
If You ae stock boost... or close... go with the stock Motocrafts... gapped a lil bit tighter than spec
Discussion Starter #8
yeah i was told use the stock motorcrafts until i absolutely need the tr6's.. but what is the number on the motorcrafts i dont want to pull a plug and then go pick some up i want to have them ready to change..
if the supercharger is on the motor... does that mean supercharger oil is still in it... i need a crash course on all of this.
i am really getting mad at my key board right now... the R button is being retarded... gat to punch it to type R
if the snout is still on the blower then the oil "should" still be in it..
Snout being the thing that bolts to the case and is holdin the upper pulley...
Fuggin R button is really pissing me off
Discussion Starter #11
when i got the motor shipped to me everything is still intact as it was just pulled from a wrecked lightning..
hmm... might not hurt to unscrew the filler hole on the snout of the eaton... just to check it...
but not knowing the condition of the oil... id say drain it and refill
that... i dont think you do... granted unless the motor is on a stand it would be cleaner to...
just unbolt the snout from the case and stat wiggleing it...
Discussion Starter #15
man... i want cool rep power like you...
ahahahaha
seriously how hard is it to take off the supercharger... im too unconfident to try it i need to see it done first or watch a video...
Is the motor in o out of the truck...
its a piece of cake man... a few vaccum lines... and plugs... which all can only go back on one way do to the design and length of the hoses... cant EFF up putting them back on... then its just the matter of unboltin the bolts you see...
if the belt is off
Discussion Starter #18
the motor is out of the truck yes
but the belt is not off... i know it will be easier to take off with the motor out
ok so to take the supercharger off all i need to do is disconnect everything CONNECTED TO the supercharger?
^ yup... just look at it and you will see... lol...
1 - 20 of 30 Posts
