1 - 20 of 25 Posts
El duderino
How important is it to install the knock sensor, especially since it is turned off in the tune?
I already have the intake in and forgot to put the knock sensor on first :shitstormretarded
A1 TRANSMISSION
since its turned off in the tune i wouldnt worry about it!!!
Mr. Crossfire
My knock sensor is installed on the new build.
I didn't install it on my new engine since our trucks don't even use it.
Fat Bastad
These trucks didn't come from the factory with a knock sensor. I've read, that because of the noise & frequency of the SC, ford decided that they couldn't use them but that was a looong time ago that I read that and my memory isn't what it used to be either. Funny thing is that I think they used them on some of their other surpercharged applications as I recall. I'm always forgetting where I put things now days.
Roach
If you decide to run a Vampire later, you can actually get a bolt in there without taking the lower off...It is reachable, especially if you have someone that has small arms.
El duderino
Roach
Close. They did come with knock sensors, hence why I have one. They are just turned off in the tune by the factory on the L's.
NO RAGRETS!!!
What he said. Everyone of us has/had one from factory. It is not used in the tune so, I (along with many others) tossed it when I swapped out the engine.
Roach
the sensor is there, it's just not turned on in the stock tune
The sensor in the valley of the block?
George\/
Not even sure it is a pid in the L computer.
Yes guy it is, I actually have mine turned on and all the values set to zero. Any other way and the truck was pulling timing after 10 psi.
El duderino
Discussion Starter · #20 ·
Yeah I have seen it in the software, just haven't bothered to mess with it yet
1 - 20 of 25 Posts
