Did you remove the bottom bolt of the shackle/hanger, then raise the axle high enough to clear the frame?Anyone using the above mentioned? I went to raise my truck an inch or so and tried to put the leaf in the second hole from the top and it seems the shackle needs modification.
Yes I removed the shackle completely, tried to place the shackles onto the leaf on the second hole above the highest setting and no go. Seems that the end of the leaf is so thick that the shackle would need to be either grounded down or maybe a JLP shackle of some sort.Did you remove the bottom bolt of the shackle/hanger, then raise the axle high enough to clear the frame?
Please elaborate on what you're having a problem with.
Ok, I gottcha...I have the newest version of the Hotchkis leaf springs with JLP shackles.Yes I removed the shackle completely, tried to place the shackles onto the leaf on the second hole above the highest setting and no go. Seems that the end of the leaf is so thick that the shackle would need to be either grounded down or maybe a JLP shackle of some sort.
I have 2.5 inches of clearance from the rear tube to the bump stop which are trimmed flat. Wanted to raise truck up an inch or so in the rear and throw in ISO up front. Ill attach a pic with my current ride height in a minute.
I bought my leafs back in November of 2014. Guess I need the jlp shackles. You have your leafs on highest setting? Have you ever tried the second holes?Ok, I gottcha...I have the newest version of the Hotchkis leaf springs with JLP shackles.
Those 2 fit fine for me. Shackles aren't too costly either.I bought my leafs back in November of 2014. Guess I need the jlp shackles
Stan and I both have 2001 trucks, he put TVS leafs on it and it was much higher than mine, so he added 2" drop shackles and now we're close.
Mike
Hotchkis leafs were a big part of making my truck hook:smt023
...then in reference to me asking if he's run FG leafsWhy I dont run fiberglass leafs.......
Put some Hotchkis leafs back there and might have to put some traction bars with heims instead of poly bushings. You would be amazed how much those bushings move.
Never have.........Id love to lose a little more weight, but dont think thats the place.
Of course we can't see the suspension spacing, but if you're trucks still sitting like this... it looks higher than Caleb's truck. Stock shackles are the way to go unless you want to dick around with ride height for street and strip. Moving leafs is a PITA LOL but I did my Hotchkis swap twice, once with the drop shackles and then again when I put the stockers in. Did it by myself, jack and jackstands, probably a couple hours if you're alone. Alternative is to bag the rear LOL.Yes this for racing Mike, seeing the issues Caleb has last week has me concerned.
