1 - 11 of 11 Posts
Ok guys I need help I loaned the truck to my little brother and the check ingine light came on and it gave me all this codes. P0740 Torque Converter Clutch Solenoid Circuit/Open
P0743 Torque Converter Clutch Solenoid Circuit Electrical
P0755 Shift Solenoid B
P0758 Shift Solenoid B Electrical
P1747 Pressure Control Solenoid A Short Circuit
P1754 Coast Clutch Solenoid Circuit
P1760 Pressure Control Solenoid A Short Circuit Intermittent
P0446 Evaporative Emission System Vent Control Circuit
P0443 Evaporative Emission System purge Control Valve Circuit
P2195 O2 Sensor Signal Stuck Lean-Bank,1 Sensor 1
P2197 02 Sensor Signal Stuck Lean-Bank 2,Sensor 1
P0403 Exhaust Gas Recirculation Control Circuit
P1229 Charge Air Cooler Pump Driver. The overdrive light keeps flashing on and off what could it be thanks in advance for the help
sounds like ya melted an 02 harness on the exhaust.....
check both front 02 sensors and corresponding harnesses
The abandoner
check the main tranny harness. and check your fuse box for blown fuses
when i first got my truck i would try to launch and everything would die and od would flash. the tranny was pinching the harness up against the bottom of the cab. i pulled the whole harness out and wrapped it up with electrical tape and re-routed it
11 Second Club
what they said! One of my rear 02's was ripped and contacting the Midpipe causing it to burn fuse #23
NO RAGRETS!!!
Has to be in the harness with all of those codes. It doesn't need to have a huge section of burned wire, loom or tape. It can be a small as one single strand of wire touching ground to create a short.
Definitely sounds like an electrical problem.
1 - 11 of 11 Posts
