I have a badly behaved 1999 Lightning (137k miles) that is giving me a real hard time............and I'm running out of ideas.
When I got the damned thing, it was running bad, misfiring and making next to no power, and it had a couple of trouble codes.
I changed out the spark plugs (poor condition), Injectors ( also looked sketchy) and coils (Mis-matched and old).................all bought from Rock Auto.
Then cleared the codes and went for a test drive.
General running was immediately improved but it had a horrible off idle stumble / hesitation.
Other than this, it was pulling strongly and making good power / boost................but NO CODES when scanned.
The intake and throttle body, etc were full of oil, as per usual...............so I removed all this and cleaned up the whole lot and re-fitted with new gaskets.
Along the way, I discovered a very suspect vacuum hose which was hanging together by a thread was was almost certainly causing an air leak, so I fixed this also.
Since the oil seemed to be getting sucked up from the pass side PCV circuit, I plugged the third hose leading down to the turkey pan at the top, near the tee piece and plugged its counterpart in the PCV line. I also plugged the pass side PCV and left the PCV socket in the valve cover open to atmosphere. My thinking for this was to at least temporarily prevent the intake pulling oil into the freshly cleaned induction system.
With high hopes for a good result, I took the Lightning for another road test and, if anything, it was even worse.
If it was a carburettor car, I'd say it was getting a lean fuel condition as the stumble was at least as bad as it was and it now felt like it was holding back power wise.
There is also the occasional sneeze back through the intake system if you try to "power through" the stumble.
However, still NO CODES this time around.
I thought I was moving in the right direction when there was a vast improvement after changing out the plugs, injectors and coils but now the Lightning runs so much worse now that the induction system isn't full of oil (lol) that it definitely feels like I've taken a huge step backwards,
Can any of you wise Lightning owners help me with some advice with this truck as I am, as I said running out of ideas..................?
