1 - 12 of 12 Posts
Divergent
Well i was on the way home from work tonight (about 10pm, 80 degrees out).
I come up to a stop sign about 2 miles from home, stop, roll slow for about 50 yards and then open it up a little...probably 75% throttle.
Runs through first, second, shifts into third and about a third of the way through third there is a massive surge so i immediately let off not knowing what it is. Well i get slowed down and its not acting funny or making any strange noises so I continue home. As soon as i pull in the drive i hear belts squealing so i know theyre wet, kill the truck, pop the hood and smoke billows out for about 2 minutes straight and coolant is everywhere.
:violent069:violent069:violent069
Slowest Silver Lightning
I'm pretty sure this is a known issue iirc. Unfortunately I can't remember anyone posting up a pic of exactly which hose in the bay it is. If you can, take a oic of the bay or circle it for future reference. This happened to a few of us.
Common issue, just the cheap OEM clamps on the hose getting weak over time. Get a high quality clamp on it and keep on going. The issue that causes this is that the hose has a restrictor in it to keep from overpressurizing the heater core at high RPMs, this unforuntely causes a higher pressure behind the restrictor and blows the hose off when the clamps get weak.
So it just the clamps. Thanks for the great info:bigtu love this site
Mine wasn't a clamp but rather a heeter core hose burst doing a burnout, of couse in front of a WRX driver. Wound up soaking and ruining the two rear passenger side coils too.
Boost Freak!!!!!!!!
If the hose didn't break and popped off the connection under WOT.
Better have the tune looked at, you may have detonation issues and lifted a head. Its common.
Divergent
Discussion Starter · #12 ·
Well hopefully it is just the hose and not a head gasket.
not a head gasket, no water in the oil but that was my first thought as well
it wasnt a hose slippin off issue, it had a hole about an inch in diameter blown through it. I'll post a pic, but to be honest i dont know a ton about all this, so it might not have even been a heater hose. but it was radiator fluid everywhere....
Ill get a pic up soon
Maybe I need to consider a plan to begin replacing all of my hoses.
Roach
This was my first thought after i got it patched up this morning
goin to the parts store for coolant and some other unrelated stuff. I'll post a pic after while of what im dealing with.
Is there a shop manual for these things so that people like me can learn about this stuff and know what theyre looking at and tearing into?
1 - 12 of 12 Posts
