21 - 28 of 28 Posts
2002 Harley F-150
Discussion Starter · #23 ·
Anything after 2003 is nvh. The block you have is fine.
**** yeah the cyl walls don’t need to be machined it just needs to get gutted, trickflow heads i ordered have 125lbs springs and 44cc combustion chambers, what should i expect to run with that?
10 second street truck
Run with what?
I'd expect you to have a machine shop install good guides and check the valves.
2002 Harley F-150
Discussion Starter · #25 ·
Run with what?
Just got the heads. what guides should i run? i read around all i could find is that the trickflow ones you should stay away from, the bronze ones where do you get them from
You may want to go magnum powers blower set up
Try MMR if they are in business.
21 - 28 of 28 Posts
