Just got my Gaylord cover, how difficult was the install? Does it go on with the plastic bed rails on or off? How did you remove the Gaylord label on the back? Also what's the best sequence while installing a bed rug as well
I left my bed rail caps on. From the under side of the fender push the tabs up as you pull it away from the fender. I think I popped 3 on each side to get the hardware under it. They just bump up a little. I laid the cover on the truck and went around the truck about a dozen times measuring and remeasuring to get it centered. Then bolted the hardware on and slowly raised it and checked for clearance on the front corners of the lid so they wouldn't rub on the bed. Be careful with this adjustment they are very close. As for the Gaylord sticker I used a heat gun on low then pealed it off. Not too hard. Good luck. I love mine and have had many compliments on it.
1 - 2 of 2 Posts
