1 - 20 of 20 Posts
Okay I have waited long enough for you guys and gals to give your times and dyno runs. [smilie=3gears.gif]
I need them so I can fill out the dyno and times forum.
:smt064
I don't want the forum to become a ghost town.
YES PLEASE DO
We HAVE ALL put A LOT into this, (and I mean each and every one of YOU).
With the new Server, Provider, and Software, we're NOW truly set up for the growth
a GREAT Forum can expect as time moves on. Please post your info so we can get these
projects moving, Avalanche has offered to do this and I think it's a GREAT Idea
PLEASE HELP US OUT
Frauderator
here is mine :D
91 octane 12 degrees of timing 410 hp
100 octane and 20 degrees of timing 437 hp
all hp is sae
my et 12.5 at 107.8
i will have some better times in december for sure
a lot of us cali L's are going to formosa for a private drag day.
incase you dont know what formosa is, its the best strip we have on the west coast. 650' above sea leval and good air :smt035
G
r/t- .322
60'- 2.028
330- 5.747
1/8- 8.805
mph- 80.20
1000- 11.479
1/4- 13.749
mph- 99.35
I'll update you in the spring. [smilie=fingersx.gif]
G
Yeah I know... I didn't even plan on running the truck that day. I'm not racing it again until spring, so I highly doubt I'll see anymore 'stock' times... But you never know. :smt069
Mods to date that would (or might) effect my ETs and speeds: (428 rwhp & 521rwtq on a dyno jet)
REM dyno tuned with a Diablo flip chip
REM intake kit
REM oil separator
REM 2500 stall converter
FFRP 1-3 suspension drop kit
Apten ported eaton
Factory Tech accumulator
4# lower JDM interchangeable pulley
Spintech cat-back system with X-pipe
JLP 58" lift bars
Flex-a-lite  270 Dual fan kit w/dual speed operation
Motorcitymods Line lock kit.
Shortened stock rear sway bar end links
Boyd Coddington Nova wheels  18x9.5  w/Nitto 404 305-55 x 18" tires (on front)
26"x11.5" ET streets (on rear)
Rear of hood raised 1.5"
Taped off grill
75% 93octane mobil -- 25% 104octane unleaded
I'm car #14................
Rich
Discussion Starter · #9 ·
Okay I have finally found the time to get the forum updated check it out it is color coded and everything. I think I have everyone that has sent me information in there if I have forgotten anyone let me know and give me your information. I still need more people so give me your damn time slips. :-?
Woo Hoo, we're cooking now (way to go all.....)
and WOW on the BIG DOG (DON) taken 1st billing  [smilie=bow.gif]
WAY TO GO NUMBER 1
Some day Don, some day......................  :sad:
Times are in my Sig., but the Dyno has changed. Use the one in the Sig until I post the new sheets......Thanks :smt109
Dyno Results: 397rwhp/ 484 torque (SAE)
I went to the area where all our HP is listed and times. If you look at my signature at the bottom of each thread it has what I have on my truck. This is just to add to your info on me. And my calculated crank HP is 484....
Project Dirty Dog
I just got a all new tune, threw the chip out the window and went with a SCT. Will be going to the dyno tommorow and will get you some numbers and hope to make it to the track tommorow for a few test runs and see what I can muster up.
Mods: LFP Ported blower,4# lower,jlp ram air, 95 maf,c&l inlet,accufab tb,shorties,jdm silver bullet,ftvb,2400 stall.4:10's.
[email protected] --Silver Dollar Raceay,  Reynolds. GA
401.9/502.1--South Georgia Corvettes Dynomaster--SAE corrected
93 octane(plus one can of Torco Concentrate)
JDM J69 chip
PSP Fast Air
JLP 5# pulley
BadBolt Th/body
Plasma Booster
NGK BR7EFs(0.040)
Gatorback belt
JDM single Magnaflow c/b
Royal Purple 5W20 oil
160 degree 'stat
Truck-Traks
16" MT ETs on Baja Wheels/rear
Dan
1 - 20 of 20 Posts
