1 - 12 of 12 Posts
Due to the nature of the hobby, all items are sold as is. You are required to cover paypal and shipping fees. Insurance and signature will be required on the more expensive items.
01+ engine wiring harness --$250
Deatschwerks 88lb injectors. Perfect for e85/race fuel. Stainless internals,adapters included. 6k miles --SOLD
Arp8740 head studs, 10k miles --SOLD
Rocker arms and hydraulic lash adjusters, 10k miles --SOLD
M.H.P stage 2 blower cams, same grind as comp cams 102600, polish wouldn't hurt. 10k miles --$400
Factory oil pump 10k miles--SOLD
Modmax forged H beam rods w/ arp2000 rod bolts. 10k miles --SOLD
Timing set,not pictured are the factory gears, comes with crank and cam gears,will need tensioners 10k miles --$90
Adjustable trickflow crank timing gears #51800505, 10k miles --$40
Factory valve body, mileage unknown, great core--$40
Discussion Starter #8
Any noticeable cuts, splices, broken tabs, etc. in the wiring harness?
I don't believe so, I didn't see anything just doing a quick glance over everything when I took the pictures. I will report back tonight if I find anything.
Discussion Starter #9
Looked the harness over pretty good, I did not see any broken clips,splices or modifications. It is dirty though!
1 - 12 of 12 Posts
