Hey wasup guys am trying to know witch leaf springs is the best route to go for, for a better 60 foot and where can they be purchase at
The flex a form fiberglass leaves are soft and shave weightHey wasup guys am trying to know witch leaf springs is the best route to go for, for a better 60 foot and where can they be purchase at
Thanks for the feed back I appreciated the advice you can give meThe flex a form fiberglass leaves are soft and shave weight
Beyond that for drag racing, stock.
The only other after market leaves are Hotchkis. They're stiff and low. Neither is really conducive to weight transfer.
Most of the work on these trucks on the rear is in correct pinion angle, proper shocks, and long bars setup with correct preload.
I like to say it is both. The components were part of the dialing in process imo.When people say they cut a said 60' time with a certain suspension component, I like to ask myself "is it the component or the person dialing in the truck". With that said, are the leaf springs on your truck damaged and you need a replacement?
Well at that point it's only a few options... Either not making the power down low, not knowing where to set the suspension, or the track is absolutely horrible and not one person is hooking lol. When going to the track I like to watch some big powered light cars go down the track. That way I know I have no excuse. Most race cars have have more power than we make and are much lighter. Weight is traction so at that point I have no excuses. Sometimes the answer is more power for better traction. Also 1.55 isn't terrible depending on your set up.I am a girl believer that some people's results are because of xyz part.
And some people's are in spite of xyz part. Lol
My truck has cut a poorly 1.55 60'
It's done that inspite of my suspension. Not because of it.
There's no setting my suspension.Well at that point it's only a few options... Either not making the power down low, not knowing where to set the suspension, or the track is absolutely horrible and not one person is hooking lol. When going to the track I like to watch some big powered light cars go down the track. That way I know I have no excuse. Most race cars have have more power than we make and are much lighter. Weight is traction so at that point I have no excuses. Sometimes the answer is more power for better traction. Also 1.55 isn't terrible depending on your set up.
You are at elevation right?There's no setting my suspension.
It's not for drag racing. It's fixed.
Hotchkis rear leaves. Belltech shackles. Hotchkis 2.1 shocks.
Hotchkis coils. Stifflers upper and lower arms. Hotchkis 2.1 shocks.
It's designed to turn. Not launch. And it's ignorantly low.
As I said, it cuts a 1.5 inspite of my suspension not because of it.
Track is an nhra big track. Prep is good.
2.9 Whipple. E85. Korn tuned. Power is there. 6.85 @ 104 on pump e85 weighing 4800lbs.
That pass was at ~700 feet daYou are at elevation right?
I went 1.57 with cal tracs and those crap jdm springs. Those springs are terrible to drive on.I have been 1.57 60 foot on MT drag radials fiberglass springs JDM coils and single adjustable shocks and I'm in a 5300 pound 4 door HD with 600 HP
Gotcha..thought you were up in elevation for some reason.That pass was at ~700 feet da
That 6.85 was my first pass off the trailer. My second pass I blew a heater hose and was done.
They transfer good though.I went 1.57 with cal tracs and those crap jdm springs. Those springs are terrible to drive on.
My house is 200 feet above sea level.Gotcha..thought you were up in elevation for some reason.
Yeah pretty much mine too. Nice to have decent air in fall.My house is 200 feet above sea level.
Yeah I'm about 45 minutes inland of Charleston SC so not to high up.. only thing that sucks is the heat and humidity. Today was 100 degrees with 100% humidity. Even in fall/winter the humidity can be bad.I've seen -1000 on a good day at pacific. Should help Marty turn in some fast times this year
