cam
stock is flat tappet hyd cam 94-95 blocks are roller ready if they have the casting up by the starter that reads F4TE.
Gen 1 Salvage Yard Owner
Some of the 93s are roller ready also..........and ATTA2D is right.
Correct!!! Look aboove the starter and see if you have F4TE as the first 4 Digits of the Block ID number. is so the block is capable of running a roller cam.
Although like has been stated a True L motor had a Flat Tappet cam in it from the factory.
