I posted this in the "nitrous forum" also but it may not be seen as much as here.
Here is a sample video of Highpower's future nitrous system and the future of nitrous altogether.
This is just not an injector pushing an RC car around like some might initially think, if so the 900 +psi would put the car into a tailspin or wall. The valve is variable and you can see how the injection into a motor will be smooth and controlled. The whole set-up will be the size of a single current injector and as you can also see it 'can' be run by wireless remote like the prototype is using in the test. The valve should flow at least 300hp.
http://www.steaknbj.com/racetested/videos/VOVCARDEMOCLIP.wmv
