My thoughts;
Should have used the Fore FC2 controller and wiring. It uses weather pack connections so no cutting or crimping for fuel pump connections. Also no "eyelet" connections that can corrode or come loose. It also allows for an easy disconnect at the hat in case you have to drop the tank again. You cutting your stock hat harness and leaving some of it up there is messy and wont allow you to sell your stock hat which can help recoup some of the fuel system cost.
Y block should not be mounted directly to the back of the rail. Y blocks should be mounted solid somewhere instead of left hanging. One reason why I dont use them and run my system in series. Another reason is less hose and clutter. One less line going to the regulator which allows for easy mounting of the regulator on the edge of the solenoid bracket. Two lines going into regulator are going to force you to come up with a mounting solution for the regulator that will be challenging.
180 Fittings on the front of the rails with lines going back makes more clutter for spark plug changes and general work in that area. Just more stuff to deal with in tight locations especially on the drivers side.
A 45* fitting at the back of the passenger side rail allows clearance from the heater tube. No need for an "extension" fitting.
Push lok is a PITA as you can surely agree with. PTFE hose and fittings are actually easier to work with when you get used to it and PTFE doesnt allow any fuel vapor smell at all and is E85 compatible. If your going to do a fuel system you should always do one that is E85 compatible even if you dont plan on running E85 because the next guy might want to.
Running the fuel feed line on the outside of the frame rail not only allows for easier fuel filter changes but you can also install a drain in line that is easier to access (for those that change fuels) Running them inside the rail is a bit tighter especially right near the hat area.
Just my .02
[email protected]
I appreciate the Input JJ! Thanks for taking the time to watch and give your thoughts, I don't mind learning!
So, it seems mostly preference type of things, nothing of actual consequence or that's being done wrong, right? I run everything by Korn and the local Lightning OG that's helping me with the truck (Rob Saner/Neil Otis), and they were happy with everything I'm doing.
The Y block idea I actually got from Gumby, i've seen his posts where he mounted it directly to the rail, and liked the way he did it. It's held there pretty well with the 90 female-female fitting. When tight, thing doesn't move at all. Not like I hung it from hoses and just dangled it there. The line clutter I get, but I dont mind alittle extra hose. I think I routed it pretty good and clean, and made sure I could get to, and access everything pretty easily. Thought ahead about plug changes, since I'll be doing alot of plug reading when tuning, and anything else I'd have to work on in that area.
Didn't want to make stuff down the road a pain lol. Part 2 shows my regulator solution, and i'm happy with it. It did take alittle fabricating (a bracket I made at the shop) and going back and forth with potential places to put it, but I think it worked out nice. You can tell me what you think when Part 2 is up.
I tried a 45 to clear the coolant crossover, and it cleared the stock one I was using as mock up, but I went to put it on the truck, and it still hit the Tim White coolant crossover. Not sure if it's that much more bulky because of the an fittings, or what, but It didn't work out when I went to put it on the truck. So I ended up grabbing a straight extension and that worked.
Korn is the one that actually recommended the Fragola push loc, and said it'd be fine for E85, if that's something I end up wanting to do down the road, it's what he uses alot. I'd definitely need more pump/injector though lol. It was a PITA to install at first for sure, but after a few fittings, I figured out what worked for clamping, how long to boil, and how to apply pressure, and they started just sliding right on for the most part, wasn't tooooo bad after some practice lol. I don't really wanna do it again anytime soon though, that's for sure lol. But it was cool, pretty neat experience doing it myself.
I like the idea of a drain in line, do you have more info on what you use or a good way to approach that? I was thinking about that after getting it together, and how I don't really wanna have to keep undoing that an fitting at the filter, increasing chances of gulling the threads. So I'd love to see what you do for that and the filter area!
Thanks again for the detailed feedback! Looking forward to what you think of part 2 and when it's all finished up.
