Yes, I hear you but I'm going to leave it. The only thing that's not going back on is EGR, And the rest can be tuned to be in range forever. we talk about that later
When you install and aftermarket hat you must use two 90* fittings for feed and return. There is maybe 3 inches of room between hat and bed area.I figure while it's down would be a good time to ask. With the fuel hat in place in the tank, what is the height at the top of the fuel lines? Basically, how much space is there between the fuel hat and bottom of the bed where first contact would be made?
Deleting EVAP without properly turning it off in the calibration screws with fuel trims for some reason. EGR deletion is a straight switch change.I remember something about turning off the EGR, also effects the EVAP system. It been like 12 years since I trashed mine..
I'm not an expert but the fuel system gets pulled into a vacuum under certain conditions to verify no leak to atmosphere, that does not cause a driveablity issue. also to vent the fuel vapor into the combustion/intake under certain conditions.
EGR is pulling exhaust back into for a couple reasons. Inert gas, cylinder cooling? reversion?
I keep the canister stuff, other than weight and a little space It will not effect my street tuck build. The EGR is in the FN way, We should talk about the EGR later
I will post the clearance pics and values when I reinstall, I want to clean the entire area and tank, plus I needed to order new hose so it might be next week
It's the correct definition. But you keep saying it like it's a rarity.I know, It might not be the correct definition but I'm sticking to it!!!
The fuel tank vent valve is closed allowing pressure to build up, the pressure sensor tells the computer that the tank is sealed and no leaks thru the evap system, the purge valve allows that pressure and fumes to be pulled into the upper intake. The fuel system is never under a vacuum.I'm not an expert but the fuel system gets pulled into a vacuum under certain conditions to verify no leak to atmosphere, that does not cause a driveablity issue. also to vent the fuel vapor into the combustion/intake under certain conditions.
