1 - 10 of 10 Posts
Up for sale is my recently built 2000 Lightning. I have owned the truck for about 2 and a half years and hate to get rid of it but have my first child on the way. Truck has about roughly 112,000 miles on body and 4500 on the New JDM Short block. Truck had a Whipple 2.3 on it and was tuned by Eric Brooks of Brookspeed in Tifton, Ga made 570/640 on pump and 640/711 on 110 at 18# of boost. I tried to sell it fully built with the whipple and everything for a month and a half with hardly any interest so I did a partial part out (sold the Whipple and fuel setup) and just got it back together last week with a stock Eaton Supercharger. This truck is setup is ready to go.
Build specs
- (9.6:1 Comp ratio) 4,500 Miles as of now.
JDM Short Block
Trick Flow 38cc Heads
Comp 130# Springs & Retainers
Comp XE270AH Stage 2 Cams
MMR 9 Qt Oil Pan & Canton Windage tray
ARP Head Studs & OEM Ford Head Gaskets
Cloyes Timing chain/Gear Set
New Oil/Water Pumps, New OEM Ford lash adjusters/Cam followers, New NGK Plugs, Everything was replaced when this motor went together.
Mods List
Metco 4# Lower
Killer Chiller
Canton Battery Located oversized IC Tank
LFP Long Tube Headers
Custom 2.5 Inch Exhaust with Flowmaster Muffler and Tip
50# injectors
90MM maf
SCT XCal 3
JDM 01+ Lower Manifold, Intercooler, & Whipple Mid plate
LFP Electric Fan Kit
Mad coil pack screws
MMR Oil Catch can kit
Tranny/Suspension
Circle D 2600 Stall
LFP Valve Body and 4x4 Tranny Pan
QA 1's all around
Metco trac Link adjustable traction bars
Metco drive Shaft Loop
Ford Racing Drop Kit
Interior and Misc.
Gauges: AEM Uego Wideband, Auto Meter Phantom Boost and oil pressure,
Innovate Electric Water Temp gauge- $60
2 295/45/18 Hankooks with 90% tread left up front
2 Mickey Thompson Drag Radial 305/45/18, 45% thread left out back
2 Spare Hankooks with 95% tread left
Pyle in dash dvd with ipod hookup
4 x Crossfire VX speakers
Viper alarm
Black housing head and tail lights
I want 14,000 obo. As I need to sell the truck. If you have any questions contact me @ 229-251-2676. Thanks, David
Discussion Starter #2
Discussion Starter #3
Discussion Starter #4
Discussion Starter #6
It hasn't been re-dyno tuned. Have no clue what it makes now, around 400-420whp would be my guess. It is on low,low boost as all I had laying around was the 4# when I sold the whipple setup. Truck runs great and is already setup for more boost or a bigger charger if you want to make 600hp. The motor, tranny and suspension is ready to go also. Basically it is ready to make as much power as the new owner wants .
how much do you want for it without the motor??
Discussion Starter #8
Truck needs a new home, anybody?
Discussion Starter #9
Discussion Starter #10
Owned by double post
1 - 10 of 10 Posts
