Hey gang,
Just installed:
2" Beltech Lowering Hangers, 2' Beltech Lowering Shackles, and 6 degree Pinion Shims on an '04 Lightning with stock leafs. I'm getting a slight vibration with low pitch humming (wah-wah-wah) form 15-20mph (loudest @20mpg). The pinion angle now sits at 0 degrees (the...
So Sunday Uncle Frank and I will be extending the 2019 race season 1 more week at Atco. I will try to lower the 2.6 KB record of 9.60 even further and UF will attempt to lower the 2.3 Whipple record of 9.53. Seeing the DA will be between -1,700 and -1,900 all day we will have a good shot. A...
I just wanted to let everyone know I purchased Stifflers new tubular transmission cross member for our trucks. I will keep everyone posted on it but I also wanted people know to know about it because of my T56 magnum swap. Brian and I talked there is actually a set of holes on the frame slightly...
Hi I’m building a 99 lightning and need some help with a few things. Where does this ground go?Where does this vac box go?Whats this and where does it go?
I appreciate any and all help thanks
Would anyone be interested in a small group buy of Trick Intercoolers?
I spoke with them and they can do 900 shipped if 5 or more a purchased. Saves about 50 bucks they are regularly 925 plus shipping. If you do not need adapter plate and run one of JCs plates that are designed for trick...
