Thank you for your response. Just to clarify, tap into the factory fuel pump connector at the pump and run that to the FC2 controller in the cab?FC2 controller should have come with the ground and power wires already installed into the controller. Run the power directly to battery using supplied in line fuse and run the ground directly to the frame.
As mentioned it installs in the cab and you use the stock power wire as the trigger/signal for the FC2. I mount them in the cab behind the driver.
JJ
The FC2 needs to be installed in a dry location.., ie inside the cab.
Use the old 12v wire from the pumps as FC signal.
The old pump ground works as a controller ground.
Run a new ground wire from the pumps to the frame.
Find the power wire in the stock fuel hat connector, harness side and use that power wire as your trigger wire for the controller.Thank you for your response. Just to clarify, tap into the factory fuel pump connector at the pump and run that to the FC2 controller in the cab?
Thank you for your clarification. Much appreciated.Find the power wire in the stock fuel hat connector, harness side and use that power wire as your trigger wire for the controller.
[email protected]
They changed the way they are made about 2 years ago so thats not a problem any longer.Not a big fan of those controllers seems like they get loose connections
Relays fail usually at the worst time and most relay's cant handle the constant amperage load, that is why controllers are the desired choice.I’m old-school give me a nice circuit breaker and a big old relay
I guess if you use the wrong relay that could be an issueRelays fail usually at the worst time and most relay's cant handle the constant amperage load, that is why controllers are the desired choice.
JJ
That looks pretty coolI use this on my truck.. simple and waterproof.
MIR has no interest in having a Truck and Lightning class any longer, even if we had more trucks in that class the last 3 years compared to the Super Stang class they still have... Oh wellWhat’s up with the ford fever classic ? I guess that’s dead too ?
