1 - 9 of 9 Posts
So here is my story, I have an 02 HD that I have had for about a year, it has 240k...
When I bought the old girl she came with a very sorry and sad electric fan setup, and as you can imagine living in Socal i had heating and overheating issues...
so I thought lets hang in one of those awesomer digical 9000 electromatic fans...
a good buddy of mine who builds race cars had told there are only two types of electric fans...those that have failed and those that are about to fail....of course i ignored his years of experience and installed it anyways
Well 500 some odd bucks and several hours of teeth mashing later, the flex a lite 270 was installed and humming like a charm....
For all of 6 months....
so last week her controller box fried and the wires were toasted.......
Well lessoned learned, I decided to go back to the factree setup, clutch fan and fan...(overpriced shroud coming in the mail soon)
Paid a couple of hundred bucks in parts, Motorcraft for sure...
During the installation of the new clutch fan, found out the feller before me had installed a NA water pump...or that's what the parts guy told me which was why i lost hours trying to figure out why the clutch wouldn't marry up to the water pump...anyways pump swapped fan installed yaaay for me right!!!
Wrong...
After two days of rolling around today, my temps shot up to 210+ on just a short run to the local deli shop for a samwhich...of course disgusted I slammed the hood down and walked into my office at home and now typing this goddamn frustrating ass story, I'm sure I need therapy after this...
I've posted this experience before .. to some criticism, but , next time it overheats check to see if there's more heat coming out of one front wheel well than the other
ie.. check for a hot wheel hub / tire .. but don't touch it as it may be really really hot
I had an overheating issue , twice .. temps would go as high as 220.. it was my front caliper draging on the rotor.. bad, old gummy inside brake hoses needed replaced
it produces SO MUCH HEAT the radiator becomes ineffective as there's a box of super hot air behind it
and if overheating on a short trip that maybe should only "just" bring it up to operating temp this may be a likely cause
otherwise I'd be doubting the new waterpump
Appreciate the advice I will pop the wheels off and see what the hell we have to going on...and if it is the pump gawddamn it...lol....but just for arguments sake 210 is way too hot for normal operation...i just want to be sure cause i have read so many misleading reports on that subject...
When my instances happened I was dealing with the original 2001 brake hoses at about 16 and 18 years old
the fist time it happened I stopped at a gas station .. realized my wheel was really hot and 4 or 5 buckets of water vaporized INSTANTLY..it was THAT hot
Sounds like you have a few issues going on. First thing I’d do is put a new thermostat in it. Next, if you ever do decide to run electric fans, is check your running voltage at idle. Every burned up controller I’ve seen was either due to inadequate wire size to the controller, bad grounds, or most often, low idle voltage.
another thought / hope for simple solution
you just put a waterpump on..possibly there's an air bubble in the cooling system that needs blead out ??
Any updates? I’m literally getting sick of my raptor fans... they draw TONS of power. I’m ready to go back to a clutch fan.
Flexalite fans have been notorious for the controllers melting/burning up for the past 2 decades of these trucks. I'm sure you're already set on going back to stock, or likely already have since this thread is so old, but another option is my fan harness kit. My setup is so absurdly overbuilt for e-fans, you won't have to worry about a controller melting down or a relay flaking out.
Reactions: 03F150HD
There's a very easy way to tell if you have a dragging rotor. Put the old gal in neutral, stick your foot out the door and try to push it. I can push mine with one foot out the door very easily. If a rotor was dragging, I doubt it. Also my garage has a barely discernable downhill tilt to it. I can put it in neutral, take my foot off the brake, and she starts ever so slowly rolling.
As for sparky fans, yeah, I don't trust them as far as I can throw them. Bought a set-up for mine in 2019, the old Mad Enterprises kit with the Mustang fan. Installed it, wired it as directed. Started it, when the fan came on, a shit-ton of smoke started coming from under the hood. Both the fan and the controller were smoking something fierce. I'm like, Oh God, I don't have a fire extinguisher. Fortunately, nothing caught fire. I put the stock clutch fan back on ASAP, and deposited the entire POS kit in the Round-Open-Top-File, aka Circular File.
Never again!
I wish my Mustang had a regular clutch fan rather than a sparky fan. But, I suppose OEM installations are far more reliable.
1 - 9 of 9 Posts
