1 - 11 of 11 Posts
L+ME-Chick=Race Time
On so far....
NGK Tr6 gapped at .034
Intercooler ice box
ported eaton /plenum
CAI
catback.... if it helps breath a bit better lol?
waiting to go on...
6lb lower
BA 3000 MAF
JLP 90mm tensioner
SCT tuner sf3
question.....
I live in So Cal coldest weather is around *40 is that cold enough to blow a whole in my stock block even If I race from a dig? that's when I like to go to my local track lol
Whining azz 'Eaton
Interesting about the cat-back question,Id say no doubt it would help.Everything else you listed sounds good-who's gonna do the tuning?
Looks like Swanson is gonna do my tunning....
I asked if 3000 was possible I was told yes and pricing was good so I went for it.
i thought that too, but every tuner I have asked said it was possible to make work. Lol I thought the bigger the better as you can see I'm a safety freak:scared003
4x4 lift
At 40, I wouldn't run the Quartermile, especially if your truck isn't tuned for that weather.
Catback won't do too much other than sound.
Long tubes and High Flow/off road pipe would make a slight difference.
Upgraded In Tank Fuel Line Kits!!!!
other things to do/check:
New Navi fuel filter
Change oil and filter
Check engine coolant
Clean if it's been a while your IC Core
Ensure your IC pump is working
Run some sea foam through the fuel system, I dump a full bottle in to an almost empty tank drive around for 5-10 miles let it sit for an hour or 2 then go fill up!!
best of luck to ya!!
Stiffler's guinea pig
I would NEVER put a 3000 on a truck with those mods. A 2400 would be plenty enough for this truck. Yes, the resolution is gonna be poor.
Discussion Starter · #11 ·
damn, well I'll see what Swanson can do, I asked and he said it should be ok.
1 - 11 of 11 Posts
