Seeing if there's any interest out there in my 2001 Ford Lightning. It has 118k on the body and <18k on the JDM built longblock(8 thread heads) and transmission. Truck was repainted a few years back and they did a good job. It shows nicely. Its got a 2.3l Whipple, single blade throttle body, Whipple CAI, Trick IC w/ 3/4" lines, Hose Hustlers kit, JC Customs mid plate with spacer, mild cams(stg 1), LFP E-fan, Afco heat exchanger w/e-fans, brushless Davies IC pump, Kooks LT headers, Magnaflow Catback w/ hi flow cats, JDM trans rebuild(shift kit, stall converter, aluminum trans pan), Built rear w/ 3:55 gears and a tru trac posi, Long bars, DS loop, f250 super duty trans cooler(radiator bypassed), New steering wheel buttons, and more im sure im forgetting. It recently had a fresh oil change, coolant flush, new ac compressor, new power steering pump, IC fluid flush, new plugs, tuned by Kevin [email protected] Motorsports in NJ. She s pretty conservative, put down 580/600 on 17psi on pumpgas 93. Truck also has the subwoofer set up behind the seats, touch screen double din, and an amplifier. Sparco Torino 2 race seats w/ 2fast4u center console. Truck is garage kept and barely driven the last couple years. Clean n clear title in hand. Not a desperate seller. Im very busy, please do not waste my time and I wont waste yours. Truck is located in Bayville, Nj 08721. Baby#2 be here in June!!! Gunna need a 4 door, so looking at Chevy SS or CTS-V. Any questions, call/text [email protected]
Looking to get $24,000
