I got a favor to a ask of yall. I have recently lost about 3lbs of boost. I checked the common problems boost bypasst valve adjustment, turkey pan hose...etc Found out it is the pcv valve I think. I took it out and could blow both ways through it. It rattles when I shake it and I cleaned it out with some starter fluid, put it back it in same problem. I got a new one from advance auto put it in. Boost is back to where it should be but truck is running rich now. Then put the original back in lost 3lbs of boost but truck is running correct a/f.
So can someone tell me if I should be able to blow both ways through it and what is the correct part number for the pcv valve. I got a price from napa but they told me $49 and it came with the hoses and T fitting.
I looked at it and noticed there is a spring inside the original one but it doesn't look to be effective.
Sorry im long winded on this subject just need some help.
