Finally was able to get off work and rip this pos out of the truck. So it's just a rod bearing in the #2 cylinder. the crank looks salvageable, but I'm gonna buy a new one! rod look perfect but it will be replaced. The bearing just failed nothing more nothing less. Everything looks perfect inside, no bluing or any signs of lack of oil. The pistons have no signs of detonation and cylinder walls are perfect.
JLP is the father of this short block!!! I do not recommend using him. his customer service sucks and doesn't stand behind his work. Multiple people have had the same problems that I have had if you look around. With that being said im not blaming this failure on him until I get an actual engine builder to check it out. There is no reason this engine should have failed with less than 5k on it in under a year.
