1 - 10 of 10 Posts
Built not bought!... bagggzzzz
ok guys on my buddies truck hes got an egr delete and got a tune with an egr delete but yet it still keeps setting an egr code right away. so he called his tuner back up and had him send him another tune once again told him that hes got an egr delete. put the tune in the truck,and it keeps throwing the code again right away . its setting a p1401 and a p1409. hes got an xcal3. help me out here guys!!
BLACK SUNSHINE
Needs to be turned off in the raw tune.....
Once tuner does it, it will be cleared and fine.
If he starts the truck and a CEL pops up everytime.....then it is NOT turned off in the raw tune.
/thread
^^^ you don't have to go to a dyno, They can turn it off in the raw tune over email.
Must be something the tuner is not doing right. mAybe he can try disconnecting the battery for a couple of mins just to see if it works.
If it's turned off in the tune like you requested then it shouldn't throw ANY codes. The fact that it's throwing codes means that it is NOT turned off. Call the tuner & get what you are paying for. You don't need a dyno to do what the tuner should be doing.
Dual Money Pits
just to clarify you guys did clear the original code before loading the new tune and running it, right?
1 - 10 of 10 Posts
