1 - 20 of 21 Posts
Discussion Starter #2
Stock Boost/VAC line;
New three way installed;
Stock EGR Manifold tube;
Stock EGR sensor;
Stock Drivers side;
Stock Passenger side (Sort of);
Install new 90* elbow;
Relocated Barometer;
Tape off end of EGR sensor plug end and stuff under wire loom;
Clean Drivers side of blower after removal of EGR system;
EVAP Cap off;
Temporary screw;
Finish capping with new Vacuum cap;
Installed new Exhaust Manifold Cap;
Amass of Vacuum lines remove in a total delete of EGR system
Clean as a Whistle and Much More clearance then before;
PAY UP SUCKA!!!
Nice pics............I need to delete mine to clean things up a bit if I don't move back to Cali.
One of those "Crazy IT Guys"
What are the advantages of the delete? The L I just bought had it done. Do I need to re add it for emmisions in TX?
Reactions: MM Shaggy
needs more cowbell!
You do not need it for emissions in Texas.
Removing it allows for cooler air charge because you are not recirculating hot exhaust gas through the supercharger.
Suhweet. Thanks for the info.
Snail Powered
wow! the how to i used was definitely not this detailed.. i'm going to have to go back and redo a few things now
Discussion Starter #11
It's on your end, there all there
SKeeT SKeeT
I can see them all just fine as well. Might be the provider you're on at the moment, your work or some public networks miight be blocking them out. :smt102
Anyone have the pictures saved?! Looking at this how to is making my head hurt 😂😂
What do you need pictures of? I see plenty of pictures above. It's not difficult to do at all. Did mine last year while doing a blower swap. I cut off the forward part of that metal strip that has the sensors on it, and just plugged the unused vacuum hoses and tucked them out of sight. Put some tape on the ends of the unused electrical connectors as well. I bought the brass garden hose cap at my Local ACE Hardware a mile away.
1 - 20 of 21 Posts
